starving for gas
Old 04-25-2006 | 12:20 AM
87 turbo II's Avatar
Default RE: starving for gas
the ECU and harness like you said would have to work. you may (like 99.8% sure) need a new transmission and then fab it with a different custom drive shaft to work with the rear axle. Everything else would be what you said you don't mind like mounting it. It will most deffinately fit though, people have done so with corvette engines. I personally hate it when people make Rx-7s piston powered but you're staying with a Mazda enigne so it's not too bad.
Old 04-25-2006 | 12:40 AM
new7's Avatar
yeah i don't like the fact that i'm not going to be using the rotory motor but what i've been told so far it would be alot cheaper to go ahead and do this for now so i could put some money back and tear apart the original motor and rebuild so anyway that's the plan thanks for the heads up
Old 04-25-2006 | 05:15 PM
new7's Avatar
how much would it cost to get a solid used rotory motor and where could i find one from a pretty reliable company i know i'm probably getting annoying so thanks for all your help so far
Old 04-25-2006 | 07:56 PM
www.rx7world.com can do rebuilds between $1000 and $8000 depending on what you want doen (how many parts replaced, if it's turbo N/A or even FD etc.) Also you can pick up used 13bts from japan with less that 40,000 miles for $2000-$3000 or so at that same site. Check the classifieds of www.rx7club.com frequently, sometimes they go for $800 - $1500 from private owners. These cheaper engines are rare but come from owners who wanted a swap and removed their old engine.
Old 04-27-2006 | 04:28 PM
new7's Avatar
where can i find a complete diagram of an 88 rx-7 gtu that includes engine,electrical,gas lines everything if not then i'll find it somehow thanks
lnwlf
11-22-2010 11:34 AM
piper
02-15-2009 12:22 PM
jettamandan
08-19-2008 10:54 AM
jayman
06-12-2005 03:40 AM
dave
02-28-2005 05:51 PM
