mazda rx8 radio reset code
Old 01-15-2010 | 01:33 PM
codymac's Avatar
Exclamation mazda rx8 radio reset code
i have a '04 mazda rx-8 and had to recently take my radio out to replace the climate conatrol switches. when i went to put it all back in the same exact way i took it all out the radio didnt work, or the climate control. it would only light up red on the display and eject/take the cd. only the fan would work on the climate control too. ive looked around and found out i need a reset code because the car thinks the radio has been stolen. ive found a few didnt codes for mazdas but none of them worked on mine. can anyone help me and tell me what code i need or what would work. if anyone has anything i would be greatly thankful.
Old 01-21-2010 | 08:43 AM
Mazmart Trini's Avatar
You will either have to call Mazda with your Vin, or take the car to them.
-Sheldon.
Old 01-28-2010 | 02:15 PM
NickC's Avatar
There are two connectors the same which are very easy to mix up. If you do the radio doesn't work or the climate control.
Old 01-28-2010 | 04:07 PM
PirateARRRX8's Avatar
Pull it all out and verify the plugs are in correctly. Also, get the serial number of the radio while you have it out. Either call or take the car to a Mazda dealership and have them look up your code.
Blue_SP20
09-27-2024 05:50 PM
LadyVet
10-03-2021 03:52 AM
otunbatomiwa
03-03-2021 06:14 AM
Blue_SP20
10-12-2012 12:46 PM
go0se
04-20-2012 04:49 AM
Quick Reply: mazda rx8 radio reset code
