RX8 vs Speed6
Old 05-26-2006 | 07:28 PM
06BLACKSPORTS's Avatar
Default RE: RX8 vs Speed6
In regards to the above post, a speed is obvious by its large grill to me, and also the embedded exhaust. And then the xenons.
The speed6 is MUCH more practical. It is AWD and if you live in any snow belt it would not be wise to get a car(RX8) that would just peel out in the snow. From that point the speed6 is more practical and its just as fast basically. For how much it weighs compared to the RX8 it has more power. Turbos are also fun. The rotary engine makes the Mazda RX better.
Its your preference since you are really comparing apples to oranges. Perhaps a test drive?
I would go speed 6 all the way. PLus for the money, if you are going to get the rx8 I might as well get a 350z. Its bigger and to me looks muc better. Faster and more horse also.
Old 05-27-2006 | 12:24 PM
blue_mazdaspeed_rx8's Avatar
Good point about snow, but he lives in houston. There isn't a lot of snow there. Also, RX8 is faster than the z on a track and is more balanced since it is a mid engine car. The rx8 also has rear seats which are often needed.
Also, since the rx8 is a rotary engine car, it MIGHT keep its value up like the rx7 did (3rd gen).
If you plan on modding, get an 8. The mazdaspeed6 has little room for mods. For around 7k you can get around 380whp (wheel, the 8 has about 200 wheel stock) which comes with turbo and ecu (and anything else you need to bolt on).
Old 05-27-2006 | 02:53 PM
87 turbo II's Avatar
modding an 8's renesis is next to impossible. Mazda has so many fail safes to keep people from modding you'd have to really know what you are doing to tweak anyhting. See Mazda was tired of people putting too many mods on the Rx-7 and blowing the engines then claiming the reliability was bad. the Rx-8's sole perpose was to get trust in rotary strong again before the re-release of the Rx-7, so we can't have RENESIS engines being modded too much, unless you really know what you are doing. It isn't meant to be modded it's meant to be the sports car for a business man, or for someone with a family (the speed6 also shares this genre of buyers), not a track car like the Rx-7 even if it does have it's fair share of 350Z killing and other good performance. I don't know if this guy wanted to tune but if he did then the speed6 would suite him better. Room or not, most upgrades in th eengine bay are replacements not add ons (when you already have a turbo like th espeed6 does). However, the Rx-8 has a killer chassis that can be further upgraded with the mazdaspeed suspension, some not-all-season-tires, the mazdaspeed magnesium wheels (14 pounds a piece!) some brembo brakes and you have the meanest handling car this side of 40k dollars (the car that beats it in handling is the Lotus Elise/Exige). He said he wants to drive winding roads, although the AWD sounds best suited for this, the sheer weight, weight dispalcement, and body roll would make it too sluggish to enjoy like th e8. I think the 8 has more straight speed and is more responsive around turns so it would "feel" faster and be more fun to drive than the other. It may not have as any conveniences but it would be more fun.
Aslo Speed6 has a possibility for heatsinking the top mounted intercooler like my car. What this means is after driving the car hard and parking it for 30 minutes or so, the heat from th eengine rises up into the intercooler and then if you start it with a hot intrercooler you lose about 15 horsepower untill you've let it cool for a few hours.
Old 05-30-2006 | 07:33 PM
^^^ thats what computers like the intercepter are for... and why it costs $2000. True that the speed would be cheaper to mod, but the 8 has more potential, but expensive.
Also, I don't think its been mentioned before, but if I remember correctly the 6 trunk is a little bigger than the 8's (mostly by height). The 8 has a good size trunk, but on vacation you can always use more trunk space.
Old 06-28-2006 | 03:36 AM
~Islander~'s Avatar
I'd choose the RX-8 over the Mazdaspeed-6, but that's only because I'm partial to rotaries.
The 'Speed-6 is a badass car too though.
Old 11-07-2006 | 05:31 PM
phade2's Avatar
I was in the market for both and ended up with the rx8. Coming from a mazda 6 S the speed6 felt pretty much the same as the 6S (faster of course). The things I did not like about the speed6 is the narrow wheel wells limit your choice of after market wheels. The other thing I did not like was the redone interior. I liked the <05 Mazda6 interiors better. The stock wheel is only 7 in. wide. The AWD system is only part time. Mod wise there is much more for the 8. the option of adding a supercharger or turbo to the 8, plus the 8's handling won me over.
Old 11-15-2006 | 05:16 AM
JBix's Avatar
When I was in the market about a month ago, I was looking at the speed6, rx8, and 350z. For the z, I could only afford the base model, whcih doesn't even come with a limited slip or traction control, so forget that. The rx8 has no low end torque, you have to ride out the revs to squeeze the power out of it, though 9k revs must sound good. There doesn't seem to be that much usable space in the rear, plus the fact that I will be moving to somewhere it snows and be able to use that awd system. I ended up going with the speed 6, a decision I am still very happy with. I love the car, the looks, the interior, the power is great and comes in pretty low. I have yet to be able to race an rx8 to compare to, but the speed 6 supposedly outruns the 8 to 60 and through the quarter, though the 8 will pull away on the top end and in the corners. A good driver in the 6 will still be able to show up a decent driver in the 8. Both good cars, both in different areas. I love my speed 6 though, its a great, comfortable car. I just made a 1200 mile trip in it that I'm not sure I'd be able to make in an rx8 without stopping every couple hours. Plus I save a quart of oil per gas tank. That's just my $.02 though.
EZE
04-19-2008 06:04 PM
RX8_wanabe
03-26-2008 04:30 PM
64microbus
10-09-2006 08:34 AM
stavrosbezas
08-12-2006 02:55 PM
humperdink
05-30-2006 02:35 PM
Quick Reply: RX8 vs Speed6
