04 Mazda Tribute Ignition Coil bolt
Old 03-04-2012 | 09:30 PM
mayberry56's Avatar
Default 04 Mazda Tribute Ignition Coil bolt
Replacing plug coil. When backing the bolt out, I noticed I was not making any progress. I saw that the bolt housing was turning also. It is a brass fitting with teeth on the outside. I finally got it out and I guess it reamed it out pretty good. Now I cannot get the brass fitting to catch in the plastic housing.
Can I buy another brass fitting? If so, where?
Any suggestions will be appreciated?
Thanks
Phillip
Old 03-06-2012 | 11:28 PM
MazdaTirol's Avatar
Are the teeth on the brass bit still there? Is it the brass bushing that the bolt goes through in the coil plug?
Old 10-01-2021 | 10:31 PM
gnoolygn's Avatar
Hey there. I have the same problem. Do you remember how you fixed it? Where you got another brass fitting?
Thanks very much,
nadiamariyan@gmail.com
Old 12-27-2021 | 01:41 PM
05_Tribute/Escape's Avatar
You might be able to use 2 part epoxy to bind insert to valve cover
Blader
04-14-2014 05:22 PM
mayberry56
03-04-2012 09:21 PM
FrankMazda6
04-29-2011 11:31 AM
stoveguy
10-03-2009 09:29 PM
