2001 Tribute Clutch Issues
I have a 2001 Tribute and have had some issues with the clutch. I reciently replaced the master clutch cylinder and can't get the bleed screw free. It is quite rusted and I believe it to be stripped out. Is this a "self bleeding clutch"? I have read a little about Ford using this. Any help would be greatly appreciated. Also, if any one has a detailed layout of the engine compartment with labeling it would help me a lot. For all of you with the door issues don't feel alone. I have ONE working exterior door handel and it is the rear passenger door. I look pretty funny getting in it. Thanks in advance for any help.
RE: 2001 Tribute Clutch Issues
The only bleed screw I know of is on the slave cylinder. I have just replaced the master and slave cylinders on my 02 tribute dx trying to cure a clutch issue. Was it the the master that you replaced or the slave?
