2003 Tribute DX 4cyl 2.0 Clutch issue
Old 07-17-2018 | 03:37 PM
ocgiii's Avatar
Default 2003 Tribute DX 4cyl 2.0 Clutch issue
I work from home, so I don't drive it too much, but a while back, I was getting a burning smell after driving for about 20 minutes. I thought it was friction around the clutch plates. It shifts fine, however there is some play in the clutch pedal, and the pin on the clutch master cylinder is falling out occasionally. I can pop it back in the floorboard and it works again. I can take it on short jaunts, but I wouldn't drive it more than ten miles from home with the way it's acting.
I'm going to put it in the shop, but I wonder if these are separate issues manifesting at the same time, or does one affect the other?
Old 07-17-2018 | 10:11 PM
simonsi's Avatar
How many miles on that clutch? Does the clutch ever slip, revs rise but speed not so much?
Excessive pin clearance doesn't sound good but it may also be a symptom of the mechanism no longer able to self-adjust with wear on the plate.
Old 07-18-2018 | 06:17 AM
ocgiii's Avatar
136,000 miles (it owes me nothing at this point)
Never.
That sounds plausible. Thanks.
Old 07-18-2018 | 03:41 PM
simonsi's Avatar
Hmmm - if the clutch doesn't slip then it doesn't explain the burning smell, only slippage will cause that, not normal usage at all.
The pin clearance is still an issue though.
Old 07-20-2018 | 12:12 AM
peedee's Avatar
136000 miles it is a wonder there is any clutch friction material left most are gone by 60 -70000 miles
Old 07-20-2018 | 06:12 AM
ocgiii's Avatar
I marvel at that myself. The mechanic who inspects it annually is amazed.
Old 10-05-2018 | 02:41 PM
ocgiii's Avatar
It passed inspection. The burning was from leaking oil. I'm going to put Liqui Moly on the next change and see what happens. I have a new clutch master cylinder that I'm going to swap in shortly, but the pin is held in by a zip tie at the moment, with no more falling out.
Old 10-06-2018 | 12:17 AM
The pin that falls out, how long is it?
Old 10-11-2018 | 03:05 PM
ocgiii's Avatar
Here's the new one that I put in, next to the one that failed yesterday. Hurray, Ford Motor Co, for crummy design and cheap materials. Yes, that's plastic.
wearules
10-21-2017 04:18 AM
eric1234
09-23-2013 09:22 PM
OLAFOELAMARGADO
05-26-2012 11:28 PM
broach1
02-21-2011 08:34 PM
robwats83
06-07-2009 09:53 AM
Quick Reply: 2003 Tribute DX 4cyl 2.0 Clutch issue
