2005 Mazda Tribute Radio Swap
Old 02-08-2021 | 12:05 PM
theslumbythesea's Avatar
Default 2005 Mazda Tribute Radio Swap
I am struggling to swap a radio into a tribute i have. I have found multiple wiring diagrams but some say different things. I am pretty sure i figured out which were the speakers as all diagrams had those listed as the same but cant figure out which wires are ground, acc, and power. the diagrams i found show the black/green wire as power but if i use a multimeter it shows nothing but i noticed if i use that as a ground the orange/green wire shows constant 12v with the car off but none of the wires give me 12v with the keys at acc? im so damn confused and have never had this much of a problem with a radio swap.
idk if the radio i have is bad or what but does anyone here have a proper wiring diagram for an 2005 tribute before i drive this thing into a wall?
Old 02-10-2021 | 05:49 PM
ipn's Avatar
ipn
Black only wire is normally the common earth , so muti-m earth lead on black and probe the other wires , you might have it sorted out by now though , good luck .
Just for extra info a 2003 year .
2003 Ford Escape Car Audio Wiring Diagram
Radio Battery Constant 12v+ Wire: Orange/Light Green
Radio Accessory Switched 12v+ Wire: Yellow/Black
Radio Ground Wire: Black
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Tan/Yellow
Left Rear Speaker Negative Wire (-): Gray/Light Blue
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
JoeA
10-02-2012 07:49 PM
mojo
07-15-2011 04:29 PM
slavashalava
02-07-2008 10:20 PM
AzDaddy
12-10-2007 02:57 PM
wyciwug
04-25-2007 10:23 PM
Quick Reply: 2005 Mazda Tribute Radio Swap
