Automatic Tranmission Got Stock in Reverse
Old 06-17-2007 | 08:07 AM
WILD's Avatar
Default Automatic Tranmission Got Stock in Reverse
Hello,
My 2001 Mazda tribute is stuck in reverse. I can’t shift it to any of the other gears. it felt like something got loose on the shifting stick. Any ideas?
Old 06-20-2007 | 09:01 PM
WILD's Avatar
Default RE: Automatic Tranmission Got Stock in Reverse
Hello again.... please help....any one...
Old 06-20-2007 | 11:29 PM
Tribby030144's Avatar
Hello wild... Try going to www.escape-central.com/1forum
Ask the fellas there are you will get a response in no time. Also try doing a search on that page
Cheers,
-Brent
Old 06-21-2007 | 06:27 PM
babyhuey's Avatar
Try checking and see if the shift cables are still attached to the transmission. Should be two of them. One transfers the forward/back movement of the shifter and other transfers side to side motion. The are both attached just below the area of the brake master cylinder.
Old 06-21-2007 | 11:38 PM
WILD's Avatar
I solved the problem thanks to "babyhuey", it was the shift cable that came off from the lever ballstud. I would just need to purchase a "C" clip to hold it down.... thanks a t/llion.
blthomas
03-29-2012 11:39 AM
858rex
10-25-2011 12:39 PM
dryheat
07-09-2011 12:11 AM
mzd507et
05-17-2011 09:50 PM
Mazdaboy2600i
01-07-2007 06:15 PM
Quick Reply: Automatic Tranmission Got Stock in Reverse
