bad brake hoses
bad brake hoses
All for of my 02 brake hoses are cracked. I have three questions:
1 How serious is this? (the rubber casing is cracked but there are no leaks)
2 What would be involved in replacing these? (Steps to be taken)
3 Once this is done, how do I bleed the brakes if that is necessary?
Thank you very much for all that you can offer!!!
Hairyg
Hairyg
The rubber being cracked is somewhat normal, but I can also tell you that I have had to replace the front drivers brake hose, as it finally broke on our 2001. It doesn't take to long to replace. Probably an hour job total.
Remove wheel, remove brake hose, replace with new hose, bleed brake.
If you don't know how currently, I would find a friend that does, so they can show you. It is also the only way to do it without using a vaccuum pump for brakes. Because you would need someone to press and hold the brake pedal down.
You are welcome. If you go http://www.harborfreight.com/cpi/cta...emnumber=92474
you will find the brake bleeder that I use. I remove all of the brake fluid from my motorcycles every year and depending upon the vehicle, usually about every 18 months to 2 years. I remove all of the fluid from the master cylinder and then refill with fresh fluid. Then starting at the rear of the vehicle, I remove fluid from the lines until I get fresh clean brake fluid. I do this at the same time that I rotate tires and it makes it easy to get done.
Good luck.
Good luck.
