Catylicconverter problem
Old 05-17-2012 | 10:34 AM
AgentOso's Avatar
Default Catylicconverter problem
03 mazda Tribute v6 I had one of my Catyliconverters replace and still haveing problems with it not accelerateing over 10 mph and wanted to see if I could just takr off the rear exhaust manifold and see if that changes anything will my tribute still start
Old 05-17-2012 | 01:38 PM
tanprotege's Avatar
If it can't go faster than 10 mph it is most likely in limp mode and you should have a veritable x-mas tree of warning lights and trouble codes. And it probabaly has nothing to do with the catalytic converter. A transmission problem is more likely.
Does the engine rev up when in N or P?
What are the trouble codes?
Old 05-17-2012 | 04:48 PM
AgentOso's Avatar
no it idles a little ruff but not bad and when i hit the gas it revs up a little and goes about ten miles an hour and if i let off the gas it dies and there is no error codes at all
Old 05-18-2012 | 09:16 AM
tanprotege's Avatar
Agent:
But why do you think it is a cat problem?
What did you do to diagnose it?
What did you do to eliminate other causes of rough idling and lack of power?
