Door open alarm
Is the alarm a continuous or intermittent sound? Either way you can start by squirting a good dose of contact cleaner into the ignition switch, and, preferably using the spare key, insert/ remove/ rotate the key to work out any muck which may be causing the contact tumblers to "hang up".
A continuous sound is often associated with corrosion of the exterior lamp sockets, making the system think lights have been left on. Contact cleaner is good for dealing with this too.
packerfaninva
03-02-2008 03:14 PM
pwb2b@mtsu.edu
09-11-2006 03:51 PM
