EGR Valve
Old 10-10-2020, 01:10 AM
noel1955's Avatar
Default EGR Valve
In my never ending search for the vacuum leak i have found that if i blow into the bottom hole, the one the exhaust line enters, the air i blow for the most part comes out the hole that goes to the throttle body. I have tested the diaphram and it holds vacuum very well. I have soaked the pintel and valve seat for a few hours in carb cleaner and it appears at this point to have helped a little. I now have to blow much harder and only a tiny bit of air comes out. I will now let it soak over night. Is it meant to be that a tiny amount of exhaust gas passes the closed valve or should there be none at all. Thanks
Old 10-10-2020, 06:09 AM
ipn's Avatar
ipn
ipn is offline
"EGR is typically not employed at high loads because it would reduce peak power output. This is because it reduces the intake charge density. EGR is also omitted at idle (low-speed, zero load) because it would cause unstable combustion, resulting in rough idle."
https://en.wikipedia.org/wiki/Exhaust_gas_recirculation
It is correct .
noel1955
12-10-2019 06:27 PM
Kumarhawaii
02-25-2009 11:01 AM
Sacred Cow
03-10-2007 05:08 AM
safa
10-12-2006 10:58 AM
vizz
01-11-2006 08:54 PM
Quick Reply: EGR Valve
