The famous and unsolved code P0351
I everyone, I sure do need your help for this one. It's about the code P0351, I put the coil #1 on #4 change all six spakplugs, went to the garage and have the injectors clean up, and the f?%$# code still on, do I have to change the injector? is there anyting I can do before I go to the dealer? And can you tell me where the ECM is, I'm thinking of changing it.
Thank's guys.
Thank's guys.
Same problem, comes and goes
I have the same problem for a few months now. I did the same things you tried. It will run fine most of the time, but usually once a day, it throws the code. It will run bad for a few minutes, then clear itself up. I have no clue what to do next. I have a code reader, and I reset it every time it throws the code.
Please explain
Please explain, was it just a cut wire? or is there something called a cutoff wire? Where is this wire, any information you have would be greatly appreciated. If I can do this, I would be more than happy to take pictures and post step by step instructions.
