Gauge Cluster stopped working????
Whats up?
The gauge cluster stopped working. Speedo, Tach, Fuel, Temp, also can't see the odometer or what position the shifter is in. Also lost the 'lighting' for the radio, 4wd, hazards etc....
I've replaced every fuse that has anything to do with the 'cluster', no luck. The big fuses under the hood B1 and B2 40A appear to be OK, if they weren't working there would be a bunch of other stuff that shouldn't work.
Any ideas for trouble shooting???
Thanks
Thanks
RE: Gauge Cluster stopped working????
Double check the 3 40 Amp fuses in the underhood fuse box they are #19, #20, and #21. In the under dash box check 10 Amp fuses #27 and #11. You might also try swapping the accessory relay in the under dash fuse box with a known good one from under the hood. These are the only power sources that I can find that might cause this. Ground point to check would be up near the under dash fuse box. There are two of them so make sure you can locate both.
ryanjaggard
07-12-2006 09:32 AM
