Hard starting
Old 11-27-2012 | 04:14 AM
Tobyrm1's Avatar
Default Hard starting
Hi all,
New to the forum! Have got a 2004 3litre tribute. Have never had any issues with my tribute in the past. It did it a few times last winter and had started doing it in the damp this winter. When cold on a morning it takes many turnings over of the engine to start the car and sometimes you need to try a couple of times. Normally a quick turn of the key and it fired straight up.
Any ideas anyone?
Thank you in advance!
Old 11-27-2012 | 09:27 AM
MazdaTirol's Avatar
Welcome to the forums! Do you have any issues while its running? Check engine light on at all? Does it happen only on the first start of the day or everytime?
Old 11-27-2012 | 12:31 PM
Tobyrm1's Avatar
Hi,
Thanks for your reply.
The car does some times not feel too pokey, just assumed that was because it does 80k miles. Doesn't seem to coincide with the starting issue. No engine like on at all. And the car only seems to do it first start of the day!
Thanks.
Old 11-27-2012 | 05:43 PM
tanprotege's Avatar
80 K miles, toby.
How about new spark plugs, wires and maybe coil pack (if that is what you have). New air filter and a cleaning of the MAF sensor with MAF sensor cleaner. Running a few tanks with Gum-out or Techron Fuel system treatment won't hurt either.
Good luck.
Old 11-28-2012 | 04:08 AM
Tobyrm1's Avatar
80 K miles, toby.
Good luck.
Had new plugs, air filter and has had some injector cleaner but made no difference. Do the plugs leads need replacing? And can a MAF be cleaned or does it need a new one?
Old 11-28-2012 | 10:38 AM
tanprotege's Avatar
Yes, replace the leads to the plugs. and yes, you can clean the MAF sensor. Use only MAF sensor cleaner spray, do not touch the sensor wires. Watch a Youtube video on how to do it right, doesn't matter what car they use in the video.
wooddy
11-06-2013 05:18 PM
kev77
10-27-2008 08:51 PM
STEVE S
11-12-2007 11:53 AM
hope2515
05-05-2007 02:04 AM
poet1234567
01-16-2007 09:32 PM
Quick Reply: Hard starting
