key wont turn
Old 06-18-2009 | 08:48 AM
toptutrles's Avatar
Default key wont turn
Mazda tribute 2001, key was very hard to insert, finally got it in but won't turn, wiggled the gear shift, steering wheel, key still would will not turn never had this problem before
Old 06-18-2009 | 05:22 PM
04tributelxowner's Avatar
Stupid question, but is it the correct key? Your Mazda key has basically the same cut as other Mazdas and Fords. If you have another Ford or Mazda key on your ring, that might be the problem. Otherwise, the key cylinder is malfunctioning and will probably need to be replaced. It's rare, but this happened to a friend of mine who had a Focus. Unfortunately, replacement usually includes the entire ignition switch assembly.
Old 06-21-2009 | 11:00 AM
LuvMyTribute's Avatar
I had this VERY same problem. I thought I was crazy, I pulled on the steering wheel, and everything. I was at work, had other people come out and try it as well. I caught a ride home, called the dealership, and had to have it towed in.
My steering column had completely locked up. They had to order me a new column straight from Mazda. I'm glad I still had it under extended warranty.
Old 06-21-2009 | 11:33 AM
oldeng's Avatar
Key or lock cylinder wear will do it too. If you have a spare key, try it. If it works well, it was the key. If it works, but badly, or not at all, it's the cylinder or steering lock mechanism that's faulty.
mr.dblanco
11-09-2012 06:25 PM
jnorthrop
12-19-2010 04:10 PM
wallerj99
01-15-2010 09:49 PM
GALINDOTWINS
01-19-2008 05:02 PM
ChrisBlue6s
08-11-2007 01:25 PM
