Keyless entry problem
Old 12-05-2007 | 03:30 PM
flitter's Avatar
Default Keyless entry problem
2003 Tribute. Keyless entry stopped working, replacement of battery did not help . Any suggestions?
Old 03-17-2008 | 07:42 PM
airmailmiller's Avatar
Default RE: Keyless entry problem
may need to reset keyfob, turn ignition on from off to just before start 8 times with keyfob on keyring, you should hear door locks engaged, keyfob should work, if not try again. should be able to reset remote for the vehicle
Old 03-21-2008 | 12:14 PM
Bubba99's Avatar
Get a new keyfob. Solved my problem.
Old 12-01-2008 | 10:14 AM
mazdi_'s Avatar
Hi Please try changing a battery. This usually helps. You can purchase a battery from our website. We offer free shipping for batteries. Please click on this link below to select the proper battery for your remote. http://www.carandtruckremotes.com/batteries.html If you changed the battery and the remote still does not work, most likely you need a new remote. You can purchase a brand new or used good condition (B-stock) remote on our website. All remotes come with a 90 day money back policy. Please click on this link to our website below http://www.carandtruckremotes.com If you have any more questions please contact us at customercare@carandtruckremotes.com You can also view our FAQ page for answers to common questions. Link below http://www.carandtruckremotes.com/faq.html Best Regards
Customer Care http://www.carandtruckremotes.com http://www.newkeylessremotes.com http://www.keylessentrystore.com
Old 12-05-2008 | 08:55 AM
Cool07's Avatar
I have a similar issue. I have recently installed a remote starter with keyless entry. My issue is that the remote starter will reach the car to activate the starter and unlock the doors from about 3 times further than the factory fob. I have replaced the battery with no difference. What could be the issue here. I have three factory fobs and they all have the same distance issue.
FYI, the distance was short before I got the starter installed.
Please help...
jpmyers15
12-16-2020 08:34 PM
willib93
11-18-2008 10:03 PM
Raes11
03-12-2008 04:28 PM
stonoguy
10-23-2007 10:49 AM
Kariz0rz
11-04-2006 09:26 PM
Quick Reply: Keyless entry problem
