Leaking water pump
Old 04-10-2011 | 01:48 AM
john.angem's Avatar
Default Leaking water pump
Hi I have a 2001 V6 3.0l Tribute and water pump is leaking badly, it doesn.t look too difficult to change, any tips on how to do it, do I need any special tools.
Old 04-26-2011 | 06:47 PM
yukonjonny's Avatar
I'ts pretty easy. No special tools are needed. It may be stuck to the block pretty well after you get all the bolts off. Just pry it off carefully so you don't mar the mateing surface for the new pump. If you drain the coolant and pull the thermostat, let me know how the relief valve (little pin thingy) on the thermostat is oriented.
extra.woo
10-17-2012 08:41 AM
jbcards2
11-14-2010 05:29 AM
kct
02-09-2010 04:53 PM
dgarcia59
08-20-2007 04:44 PM
