Master cylinder
Old 05-29-2007 | 08:37 PM
grytrib's Avatar
Default Master cylinder
I have had several leaks in both the master cylinder and brake master. When replaced was told they just wore out, but never had this problem with other cars
Old 06-05-2007 | 01:50 AM
mazzfan's Avatar
Default RE: Master cylinder
To keep the car from moving forward and to regain normal pressure, you will have to pump the brake pedals. Corrosion within the horizontal cylinder is the main cause of a leaking mazda brake master cylinder. it could be that the brake master cylinder is bad and needs a replacement. Locate and repair leak.You clean it with a brake cleaner and then wash it in solvent.
Hellohibonjour
06-16-2014 12:14 PM
Frazz45
05-27-2013 08:21 AM
krazyk011
02-24-2011 02:34 PM
kallgrer
06-06-2007 09:14 PM
backintime
05-27-2007 06:03 PM
Quick Reply: Master cylinder
