oem radio has no power
Old 06-25-2013 | 02:14 AM
luben's Avatar
Default oem radio has no power
hello to all members
im a newbie on here, so thanks in advance for all the help!
trying to upgrade the radio oem, to a Kenwood kdc-hd548u, which my cousin had given me. It had a different connector so I laid it aside, figured would look into different connectors at best buy/radio shack or somewhere.
when I reconnected/installed the oem radio back,
it has no power/no display.
I checked fuses under the dash on passenger side and they're ok.
I've tried researching site, and don't get anything.
hope someone can help...
Old 07-07-2013 | 09:23 PM
luben's Avatar
i was certainly hoping someone would at least send me to another thread or something...
come on folks, give the new guy a break, lol...
Old 07-08-2013 | 09:03 AM
Never experienced this, I leave that stuff to the professional installers.
Since it's part of computer somehow, you may want to re-set your ECU:
https://www.mazdaforum.com/forum/gen...setting-31827/
Old 07-08-2013 | 11:05 PM
luben's Avatar
thanks for your help, i'll try this on Wed, next available date for me to try and use my noggin, lol.
thanks, will post results
Old 07-16-2013 | 10:08 PM
luben's Avatar
okay, tried the quick resetting, as per the links above and nothing...
thanks for help anyway...anyway to test the radio on its own, meaning uninstalling radio and trying to see if with power (say a 9volt) I will at least see the lights on it come on??? thanks to one and all...stuck, frustrated and would hate to spend money on another radio if this one would still be in working condition. i'm broke, been out of work for a couple of years, not asking for a towel to dry my tears, just hoping for some help...thanks, bless
Old 07-17-2013 | 06:16 AM
Have you checked all the Audio fuses?
Partially remove the radio, leave it plugged in, check that you have a constant 12v
( regardless of key position) in 1 wire, and 12v when the key is on in another wire. Also check the earth wire is connected.
Old 07-18-2013 | 11:36 PM
luben's Avatar
thanks mate
will check this out this weekend, and report back...
I know someone from down your way, Eddie with Fire Ministries...
anyway, thanks again
Old 07-26-2013 | 07:25 PM
luben's Avatar
ok, I couldn't find anything! the worst part about this is that i'm even afraid to buy an aftermarket stereo, not knowing if its getting and it'll work...anyway, thanks
Old 07-29-2013 | 09:43 AM
luben's Avatar
ok, I think I tried checking correctly, with a continuity tester!
can someone mention any other steps or exact steps for me to be able to check again.
i'm trying all things before taking it to a shop. I really can't afford that though, thanks
SJ2K2004
01-20-2014 07:30 AM
saladay
07-09-2007 04:08 PM
kamikazzz
11-08-2006 06:00 AM
kamikazzz
10-21-2006 07:51 PM
zombieuk
10-20-2006 12:59 PM
