P0183 Code: Fuel Temperature Sensor A Circuit High
SOLVED - P0183 Code: Fuel Temperature Sensor A Circuit High
06 Tribute I 4-cyl
I have this code and not sure what I'm supposed to fix. After googling for an hour, I don't see that these 4cyl tributes have a fuel temp sensor. Would I have replace the pressure sensor on the rail? or would it be something on the pump/tank?
EDIT:
I ended up clearing the code and replacing the pressure sensor on the fuel rail. Did 3 drive cycles and light did not come back. I took it to get Texas state inspection and it passed. Hope this helps someone looking for a solution in the future.
EDIT:
