Passing gear not disengaging
Ok, so when I accelerate normally, (not flooring it) my tranny works through all the gears properly. However, it seems that when at 0mph, if i put the pedal all the way to the floor, it never shifts down. instead, it just continues to shoot up rpm's and i have to let off the gas just a slight bit in order to get it to shift and lower my rpm's....
any ideas on this one? Is it something that can be adjusted? I just had a rear exhaust manifold replaced (right slide, connects to the cat). would that of done something?
MAF sensor or o2 sensors???? Thanks in advance.....
Update: turns out my 3rd catalytic converter was clogged. This was radically reducing my trucks power and i wasn't able to get it up enough for the tranny to switch gears. i would check your cats.
