Possible faulty headlight switch.
Old 09-11-2009 | 10:04 AM
pete3025's Avatar
Default Possible faulty headlight switch.
Hello,
I was wondering if anyone has had the same problem that has just started in my 01 tribute. When I turn the switch one position up to the running lights they do not always come on, in fact now it is getting worse. When I do move the switch up to the second postion (headlights) they will come on but the running light are still not on. I have to keep turning them on and off until they by chance work. When I am able to get them working everything does work. I have not checked the relay, I would think this would be more of a problem with the switch itself? any thoughts on what I could do?
Thank You...
Old 09-11-2009 | 06:01 PM
oldeng's Avatar
From your description it sounds like the stalk switch alright; as I recall, the running lights are directly connected, i.e. no separate relay. You could try a good squirt of contact cleaner into where the switch is attached to the steering column, it might confirm your diagnosis and buy you a bit of time. Meanwhile, I'll double check my Protege shop manual to confirm the direct connection bit.
Old 09-12-2009 | 01:46 AM
pete3025's Avatar
Ok first, thank you oldeng for your help. But I was wrong it was the relay under the kick panel after all. My friend runs a auto radio shop he did all of the testing to see if there was a short, but he actually heard the relay clicking when he moved it up the the running light postion. So he pulled it and sure enough it was very corroded. Lucky he had some extra ford relay's laying around plugged it in and boom the problem was fixed. Now to just get that driver side inner door handle fixed. Again thank you for taking the time to answer my post
callyboy
08-23-2021 10:46 PM
rmsowell
09-05-2008 02:04 PM
TexasBear
06-28-2007 05:43 PM
mxteam
06-25-2007 07:29 PM
jasonvp
12-31-2006 11:12 PM
