Power steering pump sensor?
Old 10-04-2014 | 09:14 AM
beany_bot's Avatar
Default Power steering pump sensor?
My power steering pump has started spilling its guts. Looks to be coming from around/out the back of the little sensor thats on the engine side of the pump (has a couple of wires coming out of it). Does anyone know if I can buy just a replacement sensor in the UK. or indeed can I just put a bolt in there and blank it off?
Thanks.
Old 10-04-2014 | 10:12 AM
hixx's Avatar
The switch is to inform the PCM that there is a load, IE turning. The PCM will bump the idle up to compensate for the load. In other words, you can put a plug in the hole and probably never notice a big difference. However it will likely kick a check engine light with that switch missing.
Old 10-04-2014 | 12:19 PM
beany_bot's Avatar
Thank you thats very informative. Do you know if these can be bought independently of the whole pump? Or even know if these are known to fail?
Old 10-04-2014 | 02:21 PM
hixx's Avatar
They can be bought seperate from the pump. I replace maybe 1 every few months on various cars. Not uncommon at all.
Old 10-08-2014 | 06:19 AM
beany_bot's Avatar
Got one from dealer, £50+VAT. Hope the pump isnt knackered too!
cy131
11-29-2010 07:29 PM
renen8r
08-23-2010 08:57 AM
Jennifer
05-13-2010 11:14 AM
tungul
11-11-2009 03:08 PM
jr70895
02-03-2005 02:01 PM
