Is there a trick to separate electrical connectors?
Old 11-09-2007 | 04:48 PM
sqlis's Avatar
Default Is there a trick to separate electrical connectors?
I have an 02 Tribute LX. The odometer light went out so I attempted to remove the dash panel to get access to the bulb. After removing the 2 screws holding the panel I was able to separate the panel from the dash but can't remove it entirely because of the electrical cables held together by the connectors. I tried disconnecting the firstconnector (fog lamp)by pulling it apart but I couldn't. Is there a tool to separate electrical connectors? I stopped going further because there are probably about 8 otherconnectors (mirror adjustment, defrost, a/c adjustment, etc.)I have to disconnect and I don't want to damage the connectors. Once I figure out to pull the connectors apart, replacing the odometer light bulb should be very easy. Your help is greatly appreciated.
Old 11-09-2007 | 09:24 PM
tribby05's Avatar
Default RE: Is there a trick to separate electrical connectors?
I have an 05' and there is nothing special about removing the connection, use a thin flat screw driver,
See attached pic
[IMG]local://upfiles/12583/8AD148C9C5704A8490D5EA0B7038C1FF.jpg[/IMG]
Old 11-10-2007 | 06:34 AM
sqlis's Avatar
I thought about doing that but did not want to poke in the wrong hole and damage the connector. Your picture really helps and I will try that. I hope it's a similar technique for separating the other connectors.Thank you Tribby05!
Old 11-19-2007 | 12:47 PM
freddy's Avatar
hey guys wassup do you know by any chance if in a tribute u can put a billet grille or not ill appreciate your answers THANKS LATERZ!!!!
ericander
12-03-2009 10:02 PM
mazdadad
08-20-2006 12:28 AM
the_gray_mazda6
04-03-2006 01:47 AM
Oddball
01-07-2006 03:43 AM
