Tribute Door Lock Problem...
We're having a weird problem with the door locks on an '03 Mazda Tribute with remote entry. The automatic door lock button on the driver's door won't function. You can lock to doors with the key fob (as long as you haven't started the car). Also, the door 'ajar' warning light stays lit on the dashboard regardless of whether you open/close doors, or even turn the car off. The local dealer replaced the door lock button once under warranty, and it quit working after a week or so, (now they say it's not under warranty anymore.) Any ideas where to begin looking into this problem?
Thanks in advance
KT
Thanks in advance
KT
I am having the same problem with my 2005 Mazda Tribute. My car lock alarm (KARR) goes off while just sitting in the drive way for no apparent reason.
Also when driving now, the door ajar light on the dash and the alarm goes off constantly - all doors and back hatch are closed.
I replaced the KARR alarm with a new one and nothing. Alarms go off constantly.
To aleviate this I have to keep the car unlocked at store parking lots.
Putting the alarm in Valet mode does not help.
The problem is in the auto door lock assemblies. I have a 10 year extra warranty on the car and am going back to the dealer to see if this is a) a recall type issue (as there seems to be many that have this problem) and/or b) whether it is part of the extra warranty - and if not, then why not.
There is a recall for Recall ID # 52500 - LATCHES/LOCKS/LINKAGES:HATCHBACK/LIFTGATE:LOCK
I cannot remember if I took this back to the dealer to fix this or not, but it seems to be the problem that I am having. If they did fix it, it didn't fix it completely... will update when I ask the dealer about it. They should have a record of the fix if it was done.
Thanks in advance
KT
Thanks in advance
KT
I saw your message and thought I would reply. I have not been able to get the unlock on mine to work. I also have discovered my rear wiper isn't working. I thought I was crazy but when I read your message, I felt relief. I just acquired this car (2006 Mazda Tribute 2.3L) and have had to do a lot of work on it and it's these little things that have cause a headache.
I think I have traced the problem to the SJB "smart junction box".This is what looks like the fuse box on the right side of the console. Instead of wires going from switches to locks and motors it goes through a logic board that is part of the SBJ to decide if it wants to turn it on or not. I have a used one from EBay on the way. I'll let you know if it fixes it.
The new SJB didn't change anything. I spent several hours tracing wires. The door lock switch and the door ajar switches all go to the the SJB and all the inputs toggled when I operated the switch and open and closed doors so maybe it just needs programming?. This is an old car I'm just using for basic transportation and isn't worth all this time. I took the instrument cluster apart and removed the alarm sound module.
barronw2
07-19-2006 12:43 PM
