Tribute Tail lights
![Question](https://www.mazdaforum.com/forum/images/icons/icon5.gif)
Are the Tail lights for the 01-04 Tribute the same size as the tail lights for 05-06?
I want to put these on my 04, because i CANNOT find LED's that fit the 01-04.
http://www.wheelzngrillez.com/20matrtalir.html
Does anyone know if they will fit an 04? Or where I can find some that are made specifically made for 01-04?
![Default](/forum/images/icons/icon1.gif)
I'm sorry, I wasn't clear before. I meant the actual size of the tail lamp housing. I'm sorry, my fault. But thanks for the info!
This site has two different part numbers for 01-04 and the 05 tail lights:
http://www2.partstrain.com/store/?N=...ref=partfinder
Must be something slightly different after 04 in the size or mounting points.
![Smile](https://www.mazdaforum.com/forum/images/icons/icon7.gif)
Don't know for sure, my guess is the model #s are different because the look changed vice the mounting points. For what it's worth, here's another website that doesn't distinguish the model year for the LED lights. http://depoautolights.com/tail-light...47ad969858657a. I'd recommend you contact the dealer or the website above to ask. Worst case you order them and have to send them back...albeit disappointed.
So, what did you find out? These look like something I might be interested in getting, too...
They replied and told me that those lights WOULD fit the 01-06. So apparently the only difference is style. Therefore the size and mounting points should remain the same. Thanks for all your help!
You're welcome. Would you consider putting some pics on here when you have them installed? My passenger side taillight recently had about an inch-and-a-half of water somehow get into it - nearly covered the entire reflector - so a replacement may come sooner than later...
