Idle air control valve where is it?
Old 01-12-2014 | 05:09 PM
buzbuz's Avatar
Default Idle air control valve where is it?
Rough idle when cold, Can anybody tell me where the IAC is located and best way to get this off cheers Mazda 2 1.4 Anteres 55 plate many thanks.
Old 01-15-2014 | 07:22 PM
Juanky's Avatar
my experience is that when the iac goes south, you get a cel code. why? because the iac is a little motor, that thing either works or not. but when the engine is cold, it works on open loop mode (ignores a few sensors). what year is your car? check your intake air temp sensor, egr, coolant temp sensor.... do you have a cel code?
Old 01-17-2014 | 04:16 PM
buzbuz's Avatar
Thanks Juanky do not have a cel code its a 55 plate. It starts if i keep it at 1500 rpm for 3-4 mins then it idles ok if not it just cuts out. i bought an online man off ebay but it is really hard to find out where the components are off it, im going to have another go tomoz any advice appreciated cheers.
imperatif
04-20-2012 07:12 PM
mawill12
03-27-2012 11:10 AM
premacy
11-20-2009 04:00 AM
Go Tigers
04-01-2008 08:12 AM
REDKAISER
12-20-2007 02:52 PM
Quick Reply: Idle air control valve where is it?
