mazda 2 capella 54 plate
The nearside front windscreen wiper has juddered for a few years. I have had 3 new wiper blades in all plus a complete new arm. the dealer has not been able to cure apart from suggesting a new arm as I suspected that the arm spring was not strong enough, alas it still judders when moving from rest. I have noticed that when stopping the blade halfway the blade rubber remains at 90 degrees to the screen but the offside blade rubber has flipped over so preventing the blade from juddering.
I have tried twisting the arm so that the rubber flips back against the screen instead of remaining at 90 degrees.
I am a loss as to what the reason is so help please.
kenviv
kenviv
no, surely if I had then the off side wiper would judder, I have tried twisting the long metal arm so the rubber blade will flip back when moving across the screen instead of staying at 90 degrees to the glass, still no luck. the juddering occurs mainly when the wiper is set to intemittent, ie. theres not much rain on the glass, when raining heavy it seems a lot better but not brilliant. makes one feel like changing the car as it's so annoying. Thanks anyway
mazda 2
hi mate,dont know if this helps but i had the same kinda problem with my old 323f and an old guy in my work said to wash the windscreen with vinegar and rub both blades with a rag soaked in vinegar..i must admit it done the job but hey if it doesnt then you didnt spend too much..all the best paul
