Mazda Demio 1.3 Jap Import Room Fuse Drain
Hi,
Just wondering if anyone knows what is on the room fuse circuit on the Mazda Demio 2009 1.3 Auto. Have a slow battery drain issue. 5-7 days of no driving and the battery doesn't have enough to start. Bought a brand new battery but the issue is still there. Did some testing and have narrowed it down to the room fuse. I did suspect it from other forums. I tried disconnecting the radio, removing the overhead bulb, but the only way I can get the battery not to drain is to remove the Room Fuse.
From my testing I can work out the following is in the room circuit
Over head light Radio Keyless entry and start
just wondering if it could be something else
Thanks,
Kev
Thanks,
Kev
Hi Kev,
I have a 2010 Mazada Demio 1.3 Auto as well.
Off late I was not using it much and the battery got drained and not holding the charge.
I have a immobiliser added to my car as security, I suspect thats consuming the battery.
Can I ask you what type of battery did you replace with? If you give the model and CCA of the battery that would be great. thanks.
Regards,
Sai
Regards,
Sai
