Wiper Issue
Old 05-31-2024 | 11:58 PM
Krabgay's Avatar
Default Same front wiper issue
Originally Posted by DMozz
Hello,
I am just after some advice if anyone has any, our mazda 2 (recently purchased 2nd hand) has a front wiper issue in that when you flick the control arm they only move up slightly, and you have to keep flicking up and down about 20 times as it gradually moves up and then it will go all of the way up and back down.
All of the information I have found out there is in relation to wipers failing completely, so I am having problems determining what could be the cause of this one.
Any help would be appreciated
Hi, I also have got the same issue with the front wipers.
I changed the switch, the motor and check the fuse box and relays. They said it was fine.if you got your front wipers working fine now please do let me know, what the problem was.
Old 06-08-2024 | 04:34 AM
Find someone with a scan tool that can read live data, bring up the BCM or FBCM and read the live data.
Old Yesterday | 04:40 AM
MazdaLennox's Avatar
Hi,
I have the same issue with a Mazda 2 Skyactiv 2015 160k.
Repeated control stick activation moves the wiper arms up from horizontal by say 2cm, repeat say 10 times, then arms go to maximum height and return to horizontal.
Did you find a solution for your problem like a new motor ?
Alexmed2002
08-11-2023 01:07 PM
BCNorth
12-13-2015 09:37 PM
tributeSC0014
01-16-2012 11:01 AM
bill1986
03-27-2011 07:48 PM
rob1more
03-23-2007 02:25 PM
Quick Reply: Wiper Issue
