"Smoke" Coming from A/C Vents?
Old 10-26-2008 | 07:57 PM
Shauwney's Avatar
Default "Smoke" Coming from A/C Vents?
I've noticed that sometimes in the morning when it's kind of muggy or humid, if I turn on the A/C, sometimes a smoky mist comes out of the vents... Has anyone else ever experienced this? If so, is this NORMAL???
Old 10-26-2008 | 08:01 PM
Siber Express's Avatar
Default RE: "Smoke" Coming from A/C Vents?
It is actually Fog. And yes it is normal.
Old 10-26-2008 | 08:03 PM
Shauwney's Avatar
Thanks!
Old 10-26-2008 | 09:06 PM
apbbnbanb_07's Avatar
I've had that problem in another vehicle of mine, only it was antifreeze fumes from a busted heater core.
Old 10-26-2008 | 09:15 PM
Shauwney's Avatar
Uh oh....
Old 10-26-2008 | 09:51 PM
I would say if you are not smelling coolant in the car you are good, my 08 has done it a few times.
Old 06-21-2012 | 07:01 AM
Hudson9's Avatar
If you are still facing the same problem.then take my suggestion otherwise leave it
If it's smoke, then you probably have some wires shorting out and shouldn't drive it because there could potentially be a fire. If it's a white sweet smelling type of steam instead, look at your heater core. You still wouldn't want to drive it because if the heater core is out, then you are getting antifreeze all over the place under the dash.
In short, take it to a reputable repair shop to have it looked at.
Car Performance Parts
Old 06-21-2012 | 11:46 AM
Mazda3UR's Avatar
Most likely this is the cause. Op didn't say they smelled anything just see the "smoke". Happens when the ac is putting out 40deg temp and it is hot and muggy when the car is started. I have even seen some vents frost over.
Very much the same whenyou open your freezer door and there is "smoke"
hugocarmichael
03-10-2013 09:49 PM
stubbylong
03-10-2013 03:26 PM
CSTblank
04-12-2011 03:58 PM
eastcoaster
12-09-2007 10:37 AM
lucian688
08-17-2005 01:35 PM
Quick Reply: "Smoke" Coming from A/C Vents?
