2004 mazda3 with 2006 engine swap. NEED HELP!!!
Old 02-16-2010 | 01:02 PM
mgnaflw_mzda3's Avatar
Default 2004 mazda3 with 2006 engine swap. NEED HELP!!!
I have a 2004 with a seized engine and sent it to my uncle's transmission shop fix it and he was able to obtain a 2006 motor with low miles, but now that it's in the car it's not working because some of the components are slightly different. Is there a way to make the newer motor work in my car or does only the 2004-2005 motors work in my car? What components are compatible and which ones aren't?
Old 02-16-2010 | 07:11 PM
Tracker's Avatar
as far as i know the rpm signal is a different wire on the PCM side, other than that the only thing i could suggest is an 06 ecu, ill try looking up the wiring
dvarn
09-23-2012 04:24 PM
TaverFB
08-02-2011 12:30 PM
dodik
07-01-2007 07:34 PM
swappyRx7
03-10-2007 02:06 AM
Quick Reply: 2004 mazda3 with 2006 engine swap. NEED HELP!!!
