2005 Mazda 3 Lurching and stalling
Old 01-05-2012 | 08:49 PM
mgb's Avatar
mgb
Default 2005 Mazda 3 Lurching and stalling
Hello all,
I hope someone may be able to help with this problem. My daughter bought a used 2005 Mazda 3 from a Hyundai dealership. What has been happening is that sometimes when she stops at a light, even though she is on the brake only, the car will rev and lurch forward a couple of times and then stall out and she also was unable to start it a couple of times. The check engine light does not come on.
It has gone back to the dealership multiple times and has been there for weeks at a time, but for some reason they can't seems to find whats wrong or recreate the problem. Yet when my wife picked it up the other day from the dealship, it did it when she was leaving there and then it did it twice the next day.
I'm not really sure how hard the dealship is working to resolve this issue but I'm hoping maybe I can get some clues here while I work on finally getting the dealership to send the car to a Mazda dealer.
We also recently found out that the previous owner had takken the car to Aamaco back in August for this same problem and they were also unable to recreate the problem.
I'm wondering if this can be a computer issue?
Old 01-05-2012 | 11:31 PM
Mileage? Automatic or Standard?
Sounds like auto tranny problems. The automatic tranny fluid should be changed every 30,000 - miles. Please use synthetic. See: Flush it or Forget it | MotorWeek
and Transmission Talk | MotorWeek .
Old 01-05-2012 | 11:45 PM
mgb's Avatar
mgb
I'm sorry, I forgot to post that info.
its an automatic with 66,000 miles. would transmission problems explain the engine revving?
Old 01-06-2012 | 06:22 AM
shipo's Avatar
Sounds like auto tranny problems. The automatic tranny fluid should be changed every 30,000 - miles. Please use synthetic. See: Flush it or Forget it |*MotorWeek
and Transmission Talk |*MotorWeek .
A few comments:
  • Mazda does not recommend transmission flushes, ever; in fact, Mazda doesn't even have a recommendation for a classic pan-drop and filter change (where did you get that 30,000 mile recommendation from?). As a general rule, flushing an automatic transmission is a very-very bad idea as they were decidedly not designed for such treatment, that and the ATF can be contaminated. All too often otherwise healty transmissions fail within 10,000 miles of a flush.
  • Your comment regarding using synthetic ATF is wide of the mark. True, the ATF should be synthetic, but that in and of itself will not assure the transmission will operate properly. The fact is that there are many-many fully synthetic ATFs on the market, and each has its own properties of lubricity (or deliberate lack thereof for the clutches) and viscosity. If someone was to follow your recommendation they might think it's acceptable to say put ATF+4 in their Mazda because it is a high quality synthetic ATF; nothing could be further from the truth.
  • Regarding which ATF to use, if the Owner's Manual indicates "ATF M-V", then "Mercon-V" (and only Mercon-V) should be used. If the Owner's Manual indicates "ATF T-IV", then "Toyota Type T-IV" should be used.
  • Beware of generic ATFs which claim to meet several standars; as a general rule they don't meet any of them.
Old 01-06-2012 | 08:28 PM
Thumbs down
Originally Posted by shipo
A few comments:
That's one of Mazdas biggest flaw---never change ATF??????????. You obviously did not read my link otherwise you would have seen the 30,000 mile and the part about what really happens when you don't flush. I can understand trannies failing 10,000 miles after a first flush @ 80,000 miles (too late). My first auto transmission lasted 22,000 km. I put on an aftermarket cooler on it because the stock one on bottom of rad is insufficient. External coolers have more cooling capacities that help your tranny from being overheated and shortened life.
Automatic Transmission Fluid Temperature
Automatic transmission fluid (ATF) has a life of about 100,000 miles at 175oF. At high temperatures, it oxidizes, turns from red to brown and exhibits a burnt smell. In addition to reducing the oil’s lubricating quality. ATF manufacturers suggest that for every 20oF. increase in operating temperature above 175oF., the life of the fluid is cut in half. Hence at 195oF., oil life will be about 50,000 miles. At 220 degrees, which is commonly encountered in many transmissions, the fluid is only good for about 25,000 miles. At 240 degrees F., the fluid won't go much over 10,000 miles. Add another 20 degrees, and life expectancy drops to 5,000 miles. Go to 295 or 300 degrees F., and 1,000 to 1,500 miles is about all you'll get before the transmission burns up.
On most vehicles, the automatic transmission fluid is cooled by a small heat exchanger inside the bottom or end tank of the radiator. Hot ATF from the transmission circulates through a short loop of pipe and is thus "cooled." Cooling is a relative term here, however, because the radiator itself may be running at anywhere from 180 to 220 degrees F.!
Tests have shown that the typical original equipment oil cooler is marginal at best. ATF that enters the radiator cooler at 300 degrees F. leaves at 240 to 270 degrees F., which is only a 10 to 20% drop in temperature, and is nowhere good enough for extended fluid life.
An auxiliary transmission fluid cooler is easy to install and can substantially lower fluid operating temperatures. The plate/fin type cooler is somewhat more efficient than the tube and fin design, but either can lower fluid temperatures anywhere from 80 to 140 degrees when installed in series with the stock unit. Typical cooling efficiencies run in the 35 to 50% range.
There are a few different fluids that are better than Toyota type iV (mine is 6 speed). You must make sure on the compatability---usually says on website or phone your local tranny shop. I have changed mine and love the new fluid---even got extended warranty with it (at no extra charge---$2,000 warranty as long as i own car, next fluid flush @ 100,000 km). For a Fluid supplier to give me a free warranty such as this, they gotta have good stuff. As far as standard trannys NEO is an awesome fluid----better than OEM.
MY FLUID:
“Manufacturers‚ such as Volkswagen‚ use very good quality oil. They don’t want inferior products for the oil, steering and transmission fluids. But in all cases, our products are equal or superior,” .
In tests to find out how much fluid evaporates under use, we found that VW’s fluid has a four percent evaporation rate and most other cars had an eight to 10 percent rate. “Ours is less than one percent.”
Here is a paragraph copied and pasted from Flush it or Forget it |*MotorWeek :
The torque converter acts like a centrifuge. And any dirt particles that are in the fluid get flung out until they collect around this outside area of the torque converter. Now unless you flush, there's no way to ever clean that away. And if it isn't cleaned away, eventually it will build up to a point where it begins to flake off, those flakes can travel through the transmission, block fluid passages, cause slippage, slippage causes heat, heat kills transmissions. It's just that simple. Cleanliness is the key. See we never want to have our fluid looking like this if we can avoid it. What we want our fluid to look like always is brand new, and that means we have to flush it. We should flush it every twenty-four to thirty thousand miles.
Again, MAZDA says never change ATF????? Really? I've never heard of anything so ridiculous. My tranny lasted 22,000 km.
Old 01-06-2012 | 08:34 PM
You are over due for a fluid change if you haven't yet.
My first tranny lerched a couple times, good thing i had my foot firmly on the brake. Eventually the tranny banged extremely hard on a downshift among other things and was changed under warranty.
Old 01-07-2012 | 12:20 AM
shipo's Avatar
Once again you've pulled recommendations out of somewhere best left unmentioned. What are you, some 12 year old kid who's done just enough reading to think he suddenly knows better than the engineers? Why don't you do like your user id says and UseYourNoggin instead of spewing all of this crap around.
Old 01-07-2012 | 09:32 AM
Thumbs down
Again did you not read the links-----this is not from somewhere i dreamed up. You are the 12 year old bashing character again. You must work for Mazda. Do some re-searching for a change. Are you also familiar with the TSB on Mazda 6 6 speed Aisin Warner transmission valve body screw up? Mazda recently removed it, but here's the link, read the link: http://www.coremazda.com/tsb/mazda6/05-016-06-transaxle-slippage.pdf .
Your the one spewing crap, believing Mazdas are perfect and require no maintenance.
Old 01-07-2012 | 10:11 AM
shipo's Avatar
Again did you not read the links-----this is not from somewhere i dreamed up. You are the 12 year old. You must work for Mazda. Do some re-searching for a change. Are you also familiar with the TSB on Mazda 6 6 speed Aisin Warner transmission valve body screw up? Mazda recently removed it, but here's the link, read the link: http://www.coremazda.com/tsb/mazda6/05-016-06-transaxle-slippage.pdf .
Mazda uses scientific methods to determine the maintenance schedule of the cars they build. You are free to disagree with those recommendations, but lacking (as you are) any scientific evidence to the contrary, all you noise coming from you on this issue is just that, noise.
Old 01-07-2012 | 10:27 AM
You take Mazda's word, i'll take the rest of the world especially when my tranny blew @ 22,000 km. I'm not the only one with tranny issues. as the link said "Flush it often and keep it clean". there are other things that Mazda doesn't do for maintenance that you also need to do, but I would be wasting my breath talking to you anymore.
Actually, why don't you tell me when Mazda recommends changing the power steering fluid or the brake fluid. On my sheet it also says the brake fluid never needs replacing. It also does say "Inspect" steering operation and linkage.
Show me proof on this one.
