2005 mazda 3 sp23
2005 mazda 3 sp23
Need some help. I have cel light on car and have gotten 3 .pcodes..2177,2196 and 2089.Mechanics have repleaced 02 sensor ,MAF sensor, coils, spark plugs, ran vacumn test, fuel pressure test . Have w lights on dash brake light and cel. Turn wheel on var to the right in idle and car almost stalls. Turn signals display on dash appear intermittent. Mechanic is stumped and suggest maybe the pcm is bad. So he reset the pcm with diagnostic tool. Codes came back on. Brakes are fine.
Anybody have this issue and who can I take it to to fix. I been to 4 mechanics already. Please help
Just curious since you mention it having problems when you’re turning..... is it nearly stalling when turning and driving, or does it do it when you’re sitting at idle? Did anyone check the wiring harness for the MAF sensor? They can get stretched because it’s anchored to the battery box, especially prevalent if the right side engine mount has failed because the whole motor moves more.
SailorBob
03-06-2022 04:40 PM
Jerrythewhale
11-28-2016 06:09 AM
lime
04-10-2012 08:01 AM
