2007 mazda 3 cel
Old 02-11-2011 | 12:59 PM
alvinp48's Avatar
Default 2007 mazda 3 cel
I have 2007 mazda 3 and the cel came on. I replaced the leak detection pump on the advice of 1 service tech but the cel came right back on after about 70 miles of driving. The car runs fine except when I put gas in it and then it is very hard to start. The first tech says the purge soleniod valve is fine and I had a smoke test done on it which produced no results. Anybody have any ideas?
Old 02-11-2011 | 03:37 PM
Tracker's Avatar
whats the cel code
Old 02-12-2011 | 08:15 AM
icspots's Avatar
+1, go to an advance auto parts (or similar) and have them pull the code. That way you actually know what the issue is.
Old 02-12-2011 | 11:22 AM
alvinp48's Avatar
P2187
Old 02-12-2011 | 11:51 AM
Tracker's Avatar
P2187 Fuel system too lean @ idle
Possible causes are:
• Misfire
• Front HO2S deterioration
• Front HO2S heater malfunction
• MAF sensor malfunction
• Pressure regulator (built-in fuel injection pump) malfunction
• Fuel pump malfunction
• Fuel filter clogged or restricted
• Fuel leakage on fuel line from fuel delivery pipe and fuel pump
• Leakage exhaust system
• Purge solenoid valve malfunction
• Purge solenoid hoses improper connection
• Air suction in intake-air system
• Insufficient engine compression
No idea what you replaced but its not even close to fixing the problem. This is not an easy fix, take it to the dealer.
Blunden0024
10-22-2010 08:10 PM
pony5o
09-11-2010 11:18 AM
decrotty
07-19-2009 07:13 PM
Hadrien
01-18-2006 07:41 PM
frist44
08-26-2005 05:02 PM
Quick Reply: 2007 mazda 3 cel
