2011 Mazda 3 GTHatchback Front Grill / Audio
Old 12-31-2011 | 01:59 AM
kevinpicar's Avatar
Default 2011 Mazda 3 GTHatchback Front Grill / Audio
Looking for a replacement grill and low output on the sub.
Old 01-03-2012 | 09:33 AM
JP0317's Avatar
Ok, if the sub doesn't seem like it's working anymore make sure it's plugged in securely to the harness found in the spare area.
If you're adding an aftermarket sub you will need to run a power wire, ground, etc for the amp that will power the sub.
I'm not quite sure what 'fuse' you're looking for.
Adding a sub is really easy especially if you have a hatch. Read up on the threads here and other forums that will basically walk you through the process.
mwatt1
05-03-2012 06:42 PM
jerseyscampi
07-12-2007 04:46 AM
gregtdunn
05-31-2007 05:54 PM
MYMAZDA
08-04-2006 03:04 AM
kjlashier
07-07-2005 03:33 PM
Quick Reply: 2011 Mazda 3 GTHatchback Front Grill / Audio
