2016 mazda 3 2.0pb - engine problem
So I have some problem with my engine - it is losing torque/power over time - mostly under 3k rpm.
When I accelerate lets say at 2.5k rpm (not neccessary full throttle, it could be 2/3) it is accelerating like it was on hand brake or like something was blocking exhaust - very poor (lazy) gas pedal reaction, no power, different noise like something was blocking it.
Then when it pas 3k rpm it is kinda normal - maybe not ideal little bit less power but not that much like under 3k rpm.
And then when I disconnect battery the car is like +50NM and +50HP under 3000rpm.
Very sharp gas pedal reaction and instant acceleration even at 2500rpm. Different engine sound also.
What I did:
cleaned maf, map sensor
cleaned throttle body
new spark plugs
added something to fuel to clean fuel system
air filter is new also
checked vpower racing fuel but the same effect
But it did kinda nothing. It is not the same every time sometimes its better, sometimes it is worse but far from the state when i reset ecu (disconnect battery)
Disconnecting battery helps for 150-200km - the torque and power is there under 3k rpm. But then it is changing - mostly felt under 3k rpm...
Any ideas?
Forscan shows no error codes.
Thanx for help.
What I did:
new spark plugs
Any ideas?
Thanx for help.
Not really telling me much. Long Term fuel trim is a bit high, but not massively.
I'm used to Mazda's MMDS (IDS) display which shows actual figures, rather than just a min & max scale. Also I need to operate the throttle & watch the reactions . Its hard not having the car in front of me.
Can you bring up both the Air fuel ( A/F ) & O2 sensors, along with RPM, give it a 2 - 2500 quick rev while recording? A/F sensor maybe called O2 bank 1 sensor 1,
blackbolt22
11-07-2012 11:03 AM
isaac2484
11-27-2009 11:50 PM
Knightsman
11-15-2009 03:10 PM
