Amp Installation
Old 02-07-2008 | 03:34 PM
2.0Mazda08's Avatar
Default Amp Installation
Should I could I change the aftermarket unit and put my single din alpine in...? or should i put some line outs on the stock unit and just run a amp .... i like to listen to my music loud with a little bit of bass nothing serious just something better than stock. How would I take the door panels off... how would i go about taking the dash apart? what size speakers do i have in the front 6x9?...back speakers i wont use since theysound like 5x8's..I will put 2 10's in the trunk soi get a concert type sound.
Old 02-07-2008 | 09:24 PM
Siber Express's Avatar
Default RE: Amp Installation
5X7's in all 4 doors.
Old 02-08-2008 | 12:56 AM
2.0Mazda08's Avatar
wow that really sucks...but then why do the front speakers sound better than the back...front have to be a bit bigger....or is it because i am sitting in the front so i dont hear the speakers bubbling like the back speakers. Could i put 6x9's in the back ? I want bigger speakers these sound like speakers from a boom box.
Old 02-08-2008 | 05:31 AM
I put Polk DB570's in my F150 and I am in the process of putting a 800 watt Kenwood amp in to drive them, but even without the amp they still sounded much better than Fords Premium speakers.
Old 02-08-2008 | 02:37 PM
ORIGINAL: 2.0Mazda08
I discovered the same thing in mine andhad the same question. I knew they were the same speaker size as in the front but they sound muddier...? So I just ended up fading to the front a little bit more.
I thought they used the Ford 6x8's in their Ken? 6x8's will fit, I'm told, yes?
Old 02-08-2008 | 03:57 PM
sizzlin07's Avatar
Someone needs to clear this up. Mazda3's have 5x7s or what? I'll check crutchfield.com and see what they say. Can the Mazda radio/dash be changed over to an aftermarket standard-size CD-player? I didn't think you could without making all sorts of weird modifications...
Old 02-08-2008 | 04:00 PM
sizzlin07's Avatar
OK, crutchfield says under my 2007 Mazda3 sedan that 5x7s, 6x9s, and even 6 3/4s "will work"? What the hell.....
Old 02-08-2008 | 04:19 PM
2.0Mazda08's Avatar
i dont trust crutchfield ....or in that matter a lot of online sites that supposidly know your speaker sizes......
sizzlin07's Avatar
I used to... till now!
Old 02-08-2008 | 07:16 PM
I've heard that the OE speakers are 6x8's, but AM 5x7/6x8's and 6.5" component speakers w/a plate adapterwill work.
I'm quite sure that 6x9's are not stock and will not work.
