Bose system malfunction (possible short or bad amp)
Old 07-07-2015 | 01:44 PM
Keith Krejci's Avatar
Unhappy Bose system malfunction (possible short or bad amp)
Anyone have a problem with there Bose factory sound system shorting out? I have a Mazda 3 2011 Grand Touring hatch with the Bose navigation package. It started out as a loud pop sound through the speakers while listening to the radio.The pop sound started to get worse, thought it was because I hit a bump not the case. I went to get in my car before and I heard the popping sound directly through the speakers without the ignition even turned on. Started the car OK tried to turn the radio off but it was still popping away. I turned the car off waited a minute turned it on again. turned the car and radio on again and now there's no sound at all. Sorry for the long story but hopefully someone can help before I take it to the dealer
Old 07-08-2015 | 07:03 AM
Not knowing where in the world you are, & If your car is LHD or RHD is hard.
I've had a RHD BL with Bose having the same issue, the Bose amp is mounted under the drivers seat ( RHD ) there should be 3 wiring connectors, unplug 1 at a time and see if the popping stops. This particular 1 I worked on left the window down & it rained. the amp & wiring connectors were wet. Removed it, dried it out, didn't fix it.
Old 07-08-2015 | 07:16 AM
Heritage Mazda's Avatar
Former Sponsor
Reaper is right. Sounds like an AMP problem to me. No way I know of to bypass it. It will probably need replaced to get your tunes back.
Old 07-09-2015 | 03:17 PM
Yea I definitely had a feeling it was the amp. I'm trying to track down one without buying brand new. I wonder if anyone had tried to open and rebuild them
brianwch
07-25-2014 03:36 AM
Shiloh Greenwald
03-16-2014 04:00 PM
tebfire77
11-18-2007 08:47 PM
tebfire77
11-14-2007 09:29 AM
darkdream69
06-24-2007 12:24 AM
Quick Reply: Bose system malfunction (possible short or bad amp)
