Can mazda3 iSport 4-door sedan's key system be upgraded to keyless remote system in any way?
Old 08-26-2008 | 07:04 PM
brianxiework's Avatar
Default Can mazda3 iSport 4-door sedan's key system be upgraded to keyless remote system in any way?
Who has experienced before?
Old 08-26-2008 | 07:39 PM
Default RE: Can mazda3 iSport 4-door sedan's key system be upgraded to keyless remote system in any way?
It would be much, MUCH easier to install cruise control.
In a word, no. None of the electrical hardware is there already, so all the solenoids and cables would have to be fit and installed first. Then all the manula stuff would have to be removed and holes filled.
Shoulda'spent a little more up front and gottenwhat you wanted.
Old 08-27-2008 | 11:50 AM
icspots's Avatar
While I agree with Virgin1 that it would be a PITA to do it is totally doable to add power locks. That being said you would be looking at an aftermarket setup as it would be way way cheaper than trying to buy all the OEM parts. The next catch is that the Mz3 uses cable driven locks and most a/m lock kits are rod driven, so basically your options are more limited. A couple of people on some other forums have done it, and aside from the amount of labor (they did it themselves) seemed pretty happy with the results. If you're doing this and you have any concept of electrical stuff I'd recommend doing it yourself as most places will charge a flat fee and then something like $100/door on top of the price of the kit.
Let me see if I can find some links for you.
Old 08-27-2008 | 11:53 AM
icspots's Avatar
HERE's a link to a cable driven kit..... only $124, not bad.
Old 08-27-2008 | 11:56 AM
icspots's Avatar
And here's a quote of a reply I made on mazda3forums
There's this http://www.a1electric.com/Merchant2/...ode=W02C-RF104
rustynail installed this kit (or something really really similar) last month. He did all the install work himself and was doing a lot of trial and error so it took him a long time. Everything worked out well for him and is still working as far as I know. Here's the thread where he's talking about it, and he even did a semi-walkthrough. http://www.mazda3forums.com/index.ph...5652#msg465652
Here's also a link to a thread where Absinthe posted a bunch of links to related topics. Bear in mind that as crappy as the search function is on this site all of these came up from a search for "power locks".
http://www.mazda3forums.com/index.ph...6041#msg246041
Welcome to the forums.
Unfortunately it looks like rustynail took his pictures down, but perhaps you can get in touch with him to find them.
Old 08-27-2008 | 02:50 PM
Oh, I know it CAN be done, but is it worth it to do it, or pay someone to do it? Is it really that big a deal for the big deal it would be to do the install?
Old 08-27-2008 | 10:08 PM
icspots's Avatar
Well if you're a tinkerer and don't mind doing the work then it could definitely be worth $125.
Old 08-29-2008 | 11:26 AM
eastcoaster's Avatar
I tried adding to my 3i, and gave up. the actuators did not fit the front doors at all. the rear was ok,, but i had to cut a chunk of the plastic out. It took so much time I gave up. didnt thing the cable pull was going to be dependable.
One guy told me he wouldnt do mazda cable pull anymore and another wanted something like 150 a door.
good luck.
I did my neon and it was a breeze. the mazda is a dif animal. I bought the base model thinking I could add power doors.
ringo*
06-15-2010 05:02 PM
pepdamazdas
05-12-2010 01:40 PM
kpatz
03-27-2006 01:24 AM
Quick Reply: Can mazda3 iSport 4-door sedan's key system be upgraded to keyless remote system in any way?
