Can You Add a TurboCharger to a 2008 Mazda 3?
#21
As for your tranny question, it was brought up because if you have an auto there is no sense is turboing it because the g-series trans are extremely weak and on a manual trans things start to come apart after 350.
#22
You cant program a car to have longer longevity only do things that will hopefully make it last longer and that all depends on how well its put together. The block is strong for n/a use but the head is another story. Also econocars are not programmed for performance (unless its euro), to say that this engine is tuned to the best it can be is extremely laughable.
- Its tuned to run good enough, not much thought was put into it esp the 2.0l: Sorry to rain on your parade, but the 2.0 liter engine purports itself very well when compared to other mass produced 2.0 liter engines on the market. Taking a look at other mass-market 2.0 liter engines on the market today and I find one (and only one) that beats the Mazda3's 2.0 liter engine from a horsepower perspective. That engine? The 2.0 liter mill that comes in the Suzuki SX4 Sport; it is rated at a whopping two more horsepower than the Mazda engine.
- an example look at any honda with the k-series engine, stock for stock honda wins in performance and fuel economy (mazda is notorious for putting out fake hp/tq numbers): Geez, what a disingenuous example. The fact is, the K20 engines are expensive to manufacture, purpose built high RPM motors. Yes, the detuned version does produce a whopping seven more horsepower than the Mazda mill of the same displacement (and delivers roughly the same fuel economy); however, I suspect you were referring to the higher tuned version, a very expensive engine to build in this class, and no, it is not able to return fuel economy that is up there with the Mazda. That and correct me if I'm wrong, but don't all versions of the K20 require Premium fuel?
#23
Shipo, I'm not clear as to why you think all engines today come from the factory optimally tuned. You seem to disagree with any logic that engines can be tuned for more power or for more efficiency. You provide some good information but do not seem to be open to how modern engines are tuned from the factory or from the aftermarket.
Each year car makers bump up the output of their engines. They do not redesign their engines each year. Where does this mysterious (impossible in your words) power come from? Also, how can these chip and tuner companies continue to be in business if they produce products, costing the consumer hundreds of dollars, that do absolutely nothing? Power is coming from somewhere or there's one huge lawsuit waiting to put these people out of business.
#24
- Mazda 2.0 liter engine: same rating for the last eight model years
- VW 2.5 liter engine: rating bumped from 150 to 170 in 2008 due to a head and cam redesign
- Honda R18 1.8 liter engine: same rating for the last six model years
Let's face it, car makers have been in a horsepower and fuel economy war for a number of years now; what would be the incentive for them to leave power and/or economy on the table? The reality is that they spend millions of dollars tuning each of their engines (way more than the sum of what the aftermarket chip makers spend), and they know very well where the various thresholds are in pretty much every driving scenario.
Long story short, I don't believe the bulk of the claims of output increases for normally aspirated engines simply by changing the chip.
#25
Laughable? Sorry, like it or don't, believe it or not, improperly tuning an engine, any engine will shorten it's lifespan. Engines are tuned with many-many compromises in mind, output, longevity, economy, and emissions to name just a few; change one thing, something else changes as well. Vehicle manufacturers spend literally tens of millions of dollars on each and every engine they develop, and as part of that cost, they discover the optimal point where each of the design metrics are in balance. Combustion science is very well understood and has been so for a long-long time now, and to suggest that a company like Hypertech can come along and magically improve on output after a few relatively inexpensive dyno pulls, without jeopardizing longevity, emissions, or efficiency is, well, naive. Laughable? I think the only thing laughable is that the term was even used in this context.
Geez, how wrong can one post be?
#26
Alright, I'm going to end this useless debate right here. It is a truism that extraordinary claims require extraordinary proofs. Not even a single maker of aftermarket chipsets (Hypertech included) even remotely meets the requirement of proving the efficacy of their product in the real world. I assert that aftermarket chip makers are selling the modding public a bill of goods that is effectively worthless; that's my story and I'm sticking to it.
As a fellow engineer once signed off after a lengthy debate like this one:
Yours truly, often wrong, never uncertain.
#27
really gonna feel like a dik saying this but...its not a chip. if this was a debate about chips i would agree ex.diablesport bad, hondata good (to an extent), but its about a "plug and play" tuner, this is just so the op dont get a plug and play and a chip (soldered into the ecu) confused as the samething.
#28
#30
Ah ok, i see now, i figured you had to know the difference, just may confuse someone who dont know the difference.
blackRob4953
10-23-2017 02:29 PM
