chamber kit
RE: chamber kit
Mazdaspeed makes a nice Camber kit. I installed mine in a couple of hours on a lift. You have to drop the rear suspension x-member to get it in. (There is a bolt that hits the x-member when you are pulling it out if you don't drop the x-member.)
RE: chamber kit
Everything is adjustable on the front, the only thing not adjustable on the rear is the camber which is corrected with the new links.
With the Eibach Pro-kit, my 3i dropped ~1.2" and rear camber went from -1 degree to ~ -2.3 degrees. the Camber links brought me right back to the stock settings (-1).
Make sure you get it aligned as soon as possible. When I dropped mine before the alignment, the toe went way out and that will kill tires faster than anything.
