diy short ram intake
A few things immediately come to mind after reading your post, not the least of which is that you are lacking a scientific education.
I’m not even going to gratify that with a response.
Here is where your lack of scientific training becomes apparent. You are completely missing the scientific facts of your own analogies. Fact, vacuum doesn’t flow toward pressure, pressure flows toward vacuum. If a space vehicle starts leaking (deliberately or otherwise), the pressure moves toward the vacuum. If your version of the truth was to be believed, one would surmise that by cold starting a car in say minus forty degree weather and then immediately driving it on the freeway, then the cold wind would draw so much heat out of the radiator that the fluid inside would quickly hit minus one-hundred degrees.
Fact, heat flows toward cold as pressure flows toward vacuum.
Here again you are grossly missing the point. OBD-II engines are in fact very precise in their ability to meter fuel; direct injection engines even more-so. As for a clogged injector or an incorrect heat-range on a plug negatively affecting fuel economy; true. So? Given how precisely tuned modern engines are, it only stands to reason that if a plug or an injector (or an intake or an exhaust) is not up to the factory speck, fuel economy will suffer.
Geez, what a mish-mash; not quite sure where to begin with this one. For starters, the discussion here is about fuel economy and not absolute top-end raw power. With that in mind, here are a few facts (like them or don’t):
Wrong again. I’ll say it for the cheap seats: Any given engine provided with any given weight at any given temperature running at any given RPM will supply itself with the exact same amount of fuel EVERY TIME. This is not a point that is open for discussion amongst those that understand how these systems work; it is only contested by those whom really want to believe that their favorite product will suddenly make the engineering and scientific communities of the world look like fools for only $100. Sorry, not happening.
Ship, after completely wasting my time with that ridiculously long tread I have come to several conclusions on this where you are dead right and dead wrong at the same time. By the laws of physics and mathematical theories (key word being theories, which what they are because they aren't fact..yet). On paper, you can debunk the fact that adding a CAI would more than likely reduce MPG. However the downfall with math is the consistency. Even as engines are slaves to the OBD-II computer system, they are just as inconsistent as the behavioral changes in a girl on her period. Just like men dealing with a girl on her period OBD-II systems have tolerance. (or maybe lack there of with some men lol) Real world applications are anything but consistent. Going through the tread I agree with you and the other guys points here
Point 1. Science or not, believe it or not. Atmospheric pressure 14.xx (whatever) is not enough to actually push air in. Why, because cars are giant vacuums. You can argue pressures right before and after the tb are identical well duh, you just went from one enclose area (intake) to another enclosed area (manifold). I think where we disagree on this point is that; If you have a low pressure system inside the engine and and a higher "normal" pressure out side the engine, you are assuming that the higher pressure is pushing the air in to equalize the low pressure system inside the engine. This, however, is not the case. Assume for a moment a shuttle in space. We can all agree the space is one massive low pressure system which is also referred to as a vacuum type system. The pressure inside the shuttle is much higher obviously that what is in space. Assume, for a moment that the shuttle had a cabin leak, what happens? Under your theory, you would claim that the higher pressure system is leaking out into space to raise the pressure of space to equalize it. Much similar in a way you think the higher pressure outside the intake box pushes into the intake to equalize the low pressure system inside the engine. However, the case is, low pressure systems ALWAYS "win" over high pressure systems. In my previous space example with the shuttle, in actuality, the low pressure (space) system is drawing out (sucking out) the higher pressure system in order to have both equalized low pressures NOT the other way around. The piston drawing down is actually creating an artificial low pressure system and it is trying to equalize by drawing air from the high pressure system. You know what the say about a 4 stroke engine, SUCK, squish, bang, blow. NOT, PUSH, squish, bang, blow.
Point 2. I will agree with you that OBD-II cars are slaves to the computer and your mathematics again would be correct if the computer were specifically set to a finite exact number and could not be any other way with out the engine failing. However, real world practicality accompanied with fine tuning the ecu will state that the engine is operating under "normal" conditions given a range of values entered. Given that said having the slightest most minuscule clog in a fuel injector or air filter or having the most minuscule hotter or colder spark could actually increase or decrease in MPG because you would be taxing the engine in one system or another yet still maintaining range values for the ecu. Yes, engines work, in fact only 20% of fuel burned is converted into workable mechanical energy. So when you tax it you make the engine less efficient whether it be fuel, torque or, horsepower.
Point 3 - Again I will agree with you that MAF sensors will measure the weight of the air and that the weight of the air is greatly determined by humidity and actually temperature of the air. Thus will send an electrical signal (also just as inconsistent) to the ecu and then sends an (inconsistent) signal to the spark and fuel to mix with the air. Assume for a moment that an intake is a straw to breathe through for the engine (yes i'm bringing up this debate that people use all the time to claim that cai's are better than the stock setup). I'm leaving out here that the TB butterfly actually produces most of the restriction, which I will agree with you however, it does not produce all of the restriction. Where you think that the actual tubing of the intake is irrelevant when it comes to efficiency or mpg, I will state otherwise. So do you have to work as hard to breath through an wider diameter straight straw, or a curvy, crunched, coffee stirrer? I think it would be safe to say that it would be easier to breathe through the larger straight straw. Because I say this I do not mean bigger is always better because like we agreed to earlier, the computer will learn this and adjust accordingly. What I am understanding from you is that time has no relation to efficiency when it comes to an internal combustion engine. When in fact it does. Just because you speed up a process it doesn't mean you using the same amount of gas in just a shorter amount of time. Think of it this way, you have a stock crank pulley that can rev to 5,000 RPM's in 2 seconds and it uses 1lb of fuel (obviously i'm pulling these numbers from no where) Now if you have a light weight crank pulley lets say you can rev to 5,000 RPM's in 1.5 seconds and because the time length is shortened and the fact now that the engine doesn't have to work as hard to spin the crank it doesn't need as much fuel to produce the same output. Going further back, how does and engine "work"? Well the work comes from thermal combustion, the combustion then is transferred (partially lost) into mechanical energy. Basically, a couple of points come across here, human inputs that make the mechanical process easier means less "work" is needed to produce the output. Less work then would mean less combustion needed to produce that work. The next point would be volumetric efficiencies. TB butterfly there or not you can increase the volume of air into the engine without the computer changing fuel consumption depending on how far the range is where it becomes too lean to run in the condition that it is, hence CEL lights.
- Mass Airflow Sensors (and better still Manifold Absolute Pressure sensors) are very good at measuring the weight of the intake air. Last time I checked the worst MAP sensor I could find from the perspective of accuracy had an error rating of plus or minus one half of one percent (i.e. plus or minus 0.5%). Sounds pretty damned accurate to me.
- The computer technology that reads the output of the MAF/MAP sensors is more than sensitive enough to read the output exactly as it is sent. To say otherwise is just silly.
- Regardless of the amount of restriction upstream of the throttle body (be it a throttle body wide open to the atmosphere or a throttle body downstream of an air filter that is so clogged that the engine struggles to make enough power to keep running), the ECU provides exactly the correct amount of fuel for the available air. Said another way, if you put any given OBD-II engine on a dynamometer and then measured its BSFC at say a continuous 50HP with no intake at all, and then measured the BSFC again with the air filter so clogged that 50HP was all the engine could manage at WOT; you’d get a virtually identical number both times.
- Repeat after me, “Restriction is restriction is restriction”. When in “fuel economy mode” (i.e. tooling down the freeway at a steady speed), the throttle body/throttle butterfly provides 99.9% of the restriction upstream of the intake valves.
- More work versus less work. That argument is a red herring. Why? Because has I have oft repeated, the amount of work an engine needs to expend to fill its combustion chambers to any given level of volumetric efficiency is exactly identical regardless of what is upstream of the throttle body. Why? Because the throttle body is where the restriction occurs.
Couple of sum up points here. Your math, science, data just proves what SHOULD happen but DOESN'T ALWAYS happen and that data obtained isn't a constant but an average of what happens. With that being said, you could increase power and efficiency at the same time by running lean (better mpg) and make the process of the engine quicker, that is still within an acceptable range for the ecu. Due to inconsistencies given a range of time, transfer of energy, electrical surges and shorts, minuscule differences hotter or cooler spark, dirty injectors, air filter, MPG could be adversely affected (by adversely affect I mean +/- 1 possibly 2 mpg) Basically, your math and science proves at 4000 RPM's 'x' amount of air at a given temperature will need 'y' amount of fuel and produce 'z' output. That's all fine and dandy except that doesn't happen every time consistently. Driving habits and conditions play a huge factor in this as well.
I will respond to this tomorrow. Honestly I'm to drunk and too tired. God i love friday nights =). Tomorrow I will move this discussion into why you aren't the most loaded SOB i know, if you what you state is the absolute truth and there can never be any other possibly way. IF this were the case and with the right lawyer you could take down every major aftermarket production company that makes a cia. Because you apparently are so hard up on these statements that you claim to be the truth that the fact that companies state that these products guarantee a claim of better hp/tq/fuel eco chiefly based off of volumetric efficiencies pretty much breaks every FTC law ever imagined and in place.
There has to be some truth to these claims and just because where you may see higher hp in one portion of the rpm band but suffer elsewhere that produces a negative or net zero effect (this goes for fuel eco and tq) is grossly misrepresentation of the product. That sir, is about eight shades of illegal.
Please keep in mind that "Truth in Advertising" is a myth and there is no law against misleading claims. That said, I don't know of even a single (credible) CAI manufacturer that "claims" fuel economy improvements. To take it one step further, the only place where I've ever heard claims of fuel economy improvements due to the installation of a CAI is on internet forums.
Think about it this way; if CAIs were capable of improving fuel economy by even .0001%, don't you think every CAI manufacturer in the world would be screaming that fact from the top of every mountain?
So (you know what's coming next), do you have a link to a web site of a manufacturer of CAIs that has the chutzpah to claim an improvement in fuel economy solely through the installation of their CAI?
To take this one step further, I've only seen a handful of reseller sites that claim an improvement, however, given that most of these resellers are modeled after JC Whitney (a company that will happily sell you anything, regardless of its efficacy), those claims are easily discounted.
Myth wow, ok well i'm going to pull a you here and list off sources that clam that this is not a myth and misrepresentation of products not to mention sellers claims to improvements. Granted you CAN and with your apparently non-arguable evidence, sue the seller for these claims. Even if the manufacture of these products may not claim them, the seller does. and if the seller willingly knows that these products yield no benefits but in all reality taxing the engine then that is misrepresentation of the product and failing to comply with "truth in advertising" laws.
Much of the precedent cited in these cases stemmed from Chapter 15 of the U.S. Code, specifically a law known as the Lanham Act. Under Title VIII of the Act, titled False Designations of Origin and False Descriptions Forbidden3, any person responsible for misrepresenting goods and services is liable in a civil action brought by persons who believe that they are damaged by such acts. According to the act, people are liable of misrepresentation if their statements or actions are "likely to cause confusion, or to cause a mistake, or to deceive a to the affiliation, connection, or association of such person with another person, or as to the origin, sponsorship, or approval, of his or her goods, services, or commercial activities by another person."4
The aforementioned section came from http://www.princeton.edu/~lawjourn/Spring98/cheng.html
K&N claims that Estimated Horsepower Gain: 5.74 HP @ 4764 RPM
and that
Horsepower estimate claims are the result of specific or similar vehicle dynamometer testing. It would be impractical to test every possible vehicle configuration or year in which a particular engine may be used; in these cases, our claims are representational based upon similar engine/vehicle dyno tests. Based upon our engineering experience, we believe our estimated horsepower claims are reliable. (ok so this may be a CYA policy but they misrepresent by not telling you the negative effect of tq and fuel economy which by law could be defined as "hurting" the car and therefore are liable.)((Also to mention that products such as these could be considered "confusing" at the fact that if a consumer were to personally dyno their car after a CAI install and saw a loss in tq and were it was not represented by K&N could also be liable.
AEM Claims on their intakes that:
http://www.aemintakes.com/air_intakes.htm
A cold air intake system relocates the filter outside of the engine compartment to deliver cool air inlet temperatures. Cooler air carries more oxygen, which translates into a more intense explosion in the combustion chamber to create more horsepower and torque. But that's only part of the power equation. Tuning the inlet pipe in length and diameter to match the engine's resonance helps move more air to the cylinders (think of your engine as a big air pump), and this tuning allows us to deliver large power gains. We also monitor fuel trim correction factors and all OBDII sensors during product development to eliminate leaning the engine out and/or throwing a check engine light. (This to you is blatantly impossible due to combustion physics and/or is a gross misrepresentation of their product. Again which they could be held liable for)
and that
Seems to me that K&N has the ***** to do it. I'll have to look to be sure, and right now, after a 12hr day yesterday and 11.5hrs today at work (add in 3 rum and cokes,) I really don't care!!
The Super Bowl sucks for someone like me, in my business and that couldn't give a sh*t.
When there are as many people that get excited about the World Series, as the Stupid Bowl (w/o the hype, $$$ and politics) then I'll care.
I know I shouldn't be posting right now, but frankly, I DON'T CARE!!!
CAI manufacturer web sites I've checked off and on:
