engine light
engine light
My engine lightrecently turned on. I don't know if it's my cold air intake but I had put 10000 miles on it with my cold air intake with no problems. I checked my engine oil and it was less than half of the measuring part of the dip stick. The engine light turns off after I drive put 30 miles. Also, I bought my car in Florida, now living in Maryland. Is the engine light on because of the mass flow, temperature, or the low oil.
RE: engine light
ORIGINAL: WarDogsOfNam
Could a CAI do damage to a motor let alone cause one do die ?
RE: engine light
Car fixed. Found out the intake manifold needs to be replaced.Basically the guy told me that if the part is not made well,the butterfly value will get stuck causing the engine to choke and diefrom insufficient air. I got lucky that my warranty still covers for it even with my cold air intake.
I ran over puddles before, it's very hard to get the m3 to hydrolock with the cold air because it has a large front panel under the engine.
trace66usa
07-03-2008 04:08 PM
