Engine oil 5-50 w sn
The manual states the amount of engine oil With oil filter replacement4.3 L
But when I pour 4 liters of oil into the engine, the oil level is exactly full.With oil filter
Should I add that 0.3 of a liter??
Start the engine let it get to normal operating temperature. Then shut off the engine let it stand for about 10 minutes and recheck your fluid. You will probably find you need to add a little more.
The newly changed oil and filter will circulate through the engine while achieving normal engine heat. Shut the engine off and wait 5-10 minutes for oil to settle back into the oil pan and check your oil level.
روغن ها و فیلترهای تازه اصلاح شده در حالی که گرمای عادی موتور را به دست می آورند ، درون موتور گردش می کنند. موتور را خاموش کرده و 5-10 دقیقه صبر کنید تا روغن به درون قابلمه برگردد و سطح روغن را بررسی کنید.
[QUOTE=Callisto;181540]another way to word it?
I'll do it tomorrow and I'll tell you the result.I useAddinol Super Light 5w 40
oil. It's very transparent. Mazda's technical expert told me that when the engine is being repaired or when the oil is first poured into the car, it needs 5 liters.But in the normal case it needs 4 liters.I don't know why the technical expert doesn't do it according to the manual.
