fog lights on without headlights??
[sm=dontgetit.gif] I have a 2005 Mazda3s...I want to be able to run my fog lights with just my parking lights. Factory set-up is such that fog lights only come on when the headlights are on...anybody have any bright ideas??
RE: fog lights on without headlights??
It should be do-able if you can access the main fuse box above the passenger footwell and are able to splice in a wire to the harness and route it across the fuse box to another wire. Have not tried it but looks like it should work fine. You would then be supplying power to the fog light relay thru the parking light circuit instead of the low beam headlamp circuit.
