Freon Input
Old 09-28-2011 | 09:34 AM
Mel-Q's Avatar
Default Freon Input
Does any know how much freon does a 2008 Mazda 3 2.0l 4 cyl take I cant find the info under the hood on the sticker on in the manual???
Thx
Old 09-28-2011 | 10:41 AM
If you are planning to use a 1lb-1-1/2lb can of R134A you buy at your local parts store using a single gauge, I would recommend against it.
First of all, you will never get a full charge using one of those because once the pressure in the system equalizes w/the can pressure, no more will go in.
But the biggest reason not to do it this way is that a single gauge will never tell you what you need to know, and it can be dangerous to you personally or the system you are installing it into.
Take it to a shop with the correct equipment and have them purge, evacuate and refill the system. Yes it will cost you a bit of money, but then you will be sure to have the correct amount of refrigerant in the system, and the shop will no doubt warranty their work should something go wrong.
If I have assumed too much here and you are a professional, you should have access to that information already.
Old 09-29-2011 | 08:11 AM
Mel-Q's Avatar
Thx virgin1 and yes I will take it to a shop but we could never find how much freon it will take so it was better to ask before we input it.
Old 09-29-2011 | 09:01 AM
I don't have that info for you, but I would guess that if your professional called the Mazda dealer Service Dept they would share it with them? In general though, its not information they want the general public to know. I know they used to post that info under the hood on most cars, but it's too easy to screw it up by DIYers and is perhaps against the law these days.
Just my .02.
gcracraft
11-03-2013 07:17 AM
deershoot3r
08-08-2011 12:47 PM
MustStangSally
09-27-2009 04:10 PM
CombatMedic
08-09-2009 06:42 PM
Meggzy07
06-09-2007 08:30 PM
Quick Reply: Freon Input
