Front Strut Bar
Old 06-23-2007 | 01:42 AM
knightrider's Avatar
Default Front Strut Bar
Hi all, jus wanna noe do we hv to remove the two original strut base (metal piece) from our ride before we put in the strut bar?After securely tightened the aftermarket strut base,i've found out that the handle bar cant be tighly secured on the based, seems like i cant further tighten e nuts..(there's some plastic ring on the nut that restrict the turning) Is it normal?
Old 06-23-2007 | 03:28 PM
Default RE: Front Strut Bar
I installed my Vibrant bar with the factory bases intact.I did this for clearance over the battery box and because I wasn't sure either.I was later told that either way is acceptable. The OEMs seemed beefier, so I wanted to keep them.
Ihad a bit of trouble w/the underhood insulation, so... I removed it. Problem solved.
EthereaL
04-19-2008 07:03 PM
SCCAProtege5
11-07-2007 09:26 PM
element000101
09-30-2007 10:57 AM
ronin4580
06-20-2006 07:22 PM
Spaz218
02-25-2006 12:03 AM
Quick Reply: Front Strut Bar
