Half dash brightness and wipers work seperate from washer fluid.
Old 02-08-2010 | 08:09 PM
scott610's Avatar
Lightbulb Half dash brightness and wipers work seperate from washer fluid.
Long story short battery went bad. Replaced battery (the OEM batteries are junk along with stock Alt.) Car runs great. All of a sudden I got out at night and my instrument cluster is dim and my wipers and washer fluid will not work at the same time. I have no clue were to start I hate electrical. Brightness adjuster does work but only within the new brightness. Radio lighting effects are still ok. Thanks for any clues or inputs.
Old 02-08-2010 | 08:11 PM
scott610's Avatar
almost forgot I have a 07' 3 sedan.
Old 02-08-2010 | 09:12 PM
Tracker's Avatar
you have something drawing to much power, if you already went though a battery and alt, then something is obviously wrong, have your dealer take a look @ it not just replace ****
Old 02-09-2010 | 09:52 AM
icspots's Avatar
Also curious, but have you pushed the button between the tachometer and speedometer while the lights are on? When the headlights are on that button switches the cluster from day to night mode. With the headlights off the button toggles the red back lighting between 6-7 settings..... whichever you select with the lights off will be the brightness of the "day" setting with the lights on.
I can't comment on what's going on with the wipers though.
branchm
12-10-2013 06:40 PM
Icarus1990xx
02-15-2010 10:29 PM
protege98
03-24-2009 08:21 PM
rikardo76
01-23-2009 02:01 PM
anthonytsi
11-12-2008 04:37 PM
Quick Reply: Half dash brightness and wipers work seperate from washer fluid.
